Do you mean the spot where the twisted windings are soldered together?Is it just me, or does it look like there was an arc between the winds on the top right, right in front of the capacitor.
I'm thinking your BNC connector has failed (or is DOA).The other core made no difference, so I don't think I have the wrong type. There has to be some nuance I'm missing. If I connect the same coax into a 50 ohm dummy load the SWR reads as almost perfect, so as far as I know the meter isn't way off.
I just noticed that the SWR with the 2.5k dummy load is fairly good on 80m but still high on other bands. Could that indicate anything about what's wrong?
I had the same thought. I tried three female and two male BNC connectors in all the experimenting I've done today with no change.I'm thinking your BNC connector has failed (or is DOA).
When I built one of these, I soldered everything. I would not trust press fit connections.I had the same thought. I tried three female and two male BNC connectors in all the experimenting I've done today with no change.
Since you bring that up... I'm using solder-type connectors. The coax braid just gets press-fit into the housing. Will that make a good enough connection? I wasn't worried about it initially since the same connectors work fine with the 50 ohm dummy load, but with no other ideas panning out I'm starting to circle back that way. The multimeter shows a good connection end-to-end and no short between the center conductor and braid.
A possibly unrelated thing about soldered coax connectors (and you may know this already, if so, sorry). But when dealing with the braid of a coax connector, its helpful to "comb" it out, so its very neat (a single layer or braid where none of the metal strands overlap and contact the washer) where everything clamps together.
Other than that, it doesn't sound like the connector at this point.
Joel
Bad coax maybe?Well this officially makes no sense. I'm out of ideas. The SWR into the 2.5k load is very low on 80m and fairly low on 20m, almost to the point of being acceptable if it happened with a real antenna. Everywhere else it's moderate to high.
I don't think so. The same coax works fine into a 50 ohm load. It's only when the unun is attached that it acts up.Bad coax maybe?
are those wires coated with some enamal or something, and nothing is worn off, I don't know if it would effect anything.I attached the connectors the easy way: strip the insulation, fold the braid back over the collar, solder the pin to the center conductor, and screw it together. I was a little concerned that the braid wouldn't make good contact, but everything seems to be working in that regard with the 50 ohm load. When I'm more experienced I'll probably try the more advanced method.
At this point I think we've ruled out the connectors, the cores, and the wiring. Here are pictures of the original transformer that started all this. Now that it's out of the box maybe something screwy is visible that wasn't before.
View attachment 131624View attachment 131625View attachment 131626View attachment 131627
after combing out the braid, and moving it over the "clamp", it'll make great contact when you screw it down. make sure you slide the approriate items over the cable BEFORE you cut it.I don't think so. The same coax works fine into a 50 ohm load. It's only when the unun is attached that it acts up.
That said, just to be certain, this is the procedure I used to attached the connectors to the coax: Installing Connectors the Right Way
My connectors are slightly different from the ones they used, but have the same basic components:
Is that the best way to go about it for someone who doesn't have the tool mentioned earlier? I'm still unclear how the braid makes good contact to the connector housing.
They are enamel coated. Given how hard it was to strip the ends for soldering I don't think anything wore off where it shouldn't. If part of the coating did wear off the core isn't conductive anyway.are those wires coated with some enamal or something, and nothing is worn off, I don't know if it would effect anything.
Joel
They didn't include instructions (bought a bulk pack), but what you sent is what I did. All the connectors feel firmly in place and the multimeter shows good connectivity end-to-end with no shorts. It looks like we can rule out bad cabling, which in a way is disappointing as it means I'm back to having no idea what's messing things up.after combing out the braid, and moving it over the "clamp", it'll make great contact when you screw it down. make sure you slide the approriate items over the cable BEFORE you cut it.
The only other thing I can suggest is that when screwing the whole thing down, just turn the nut part, not the connector part.
They're sometimes (frequently) a little different from each other, the following instructions might help, hopefully the connector came with instructions.
