Antenna for my car
Smyrna, Delaware
I'm looking for a low profile antenna for my mobile setup in my car. I mainly listen to the 800mhz apco 25 found here in Delaware. The car is a corvette and cant see putting a huge antenna on it. Please help
trap5858
Doylestown PA & Milton DE
If you are using a handheld, the rubber duck antenna should do quite well for the systems you want to listen to without putting an external antenna on the car.
Metrofire31
Auburn-Opelika, AL
Low Profile Antenna
If you want an installed antenna (NMO), I would recommend the Laird Phantom series. You could start out with the 800 MHz version and it comes in either black or white. They are excellent antennas and are used a great deal by public safety agencies. They also have a UHF and a VHF version. The UHF and the 800 are similar in size. The VHF model is about the size of a softball. :)
code3cowboy
CA-CZU
For your system you can use a quarter wave whip, and it will be just fine. QWB800 should not cost you more than $10. Put it on the center of your trunk or you can do a lip mount.
N
N_Jay
Guest
I assume Corvettes are still fiberglass.
Your antenna will need a ground plane. Metal screen or tape on the underside of the mount will work.
A 1/4 wave whip is almost as good ans anything else, and you may even find a nice place to put it where it does not show (Maybe in the rear deck)
I use a small magnet mounty marine radio antenna and i have a range of about 50 60 miles in each direction i use a pro 95 scanner in the car i like it since it is a very low profile antenna i bought it a year ago on ebay for around $25
prcguy
I think the first response was the right idea considering a fiberglass car. An antenna on the handheld scanner will probably work better at 800MHz than a remote mounted one with feedline loss.
prcguy
Luis_R
True, or could use a non ground plane coax kit as well. I've soldered a ground wire to the mount instead of metal tape or screen and have noticed better results ( less loss & less reflection ).
