Antenna for the GT-3
teufler
ST PETERS, MISSOURI
I recently picked up a GT-3, then decided to get a longer antenna. I got the Nagoya NA-771. Now what is the trick to screwing it in. Proper male sma, except it will not screw in. Wondering if others have bought the antenna and if there is a trick.Does the antenna need som e plastic at the base trimed down. The threads just don't catch to start threading.
teufler
ST PETERS, MISSOURI
problem solved
had to get out a grind wheel and reduce the base diameter alittle. The black plastic at the base of the antenna, is just alittle too big for the insert on the radio. Once the black plastic was reduce, in diameter, it screwed in fine.
