Antenna Help Needed
CYUL
Montreal, Canada
I have a helical antenna that was originally designed for 1.8-2.0 GHz. I'd like to tune it down to L-Band (1540MHz). See the attached pic. 11 turns, 2" diameter, 1.5" between turns.
thebaldgeek
thebaldgeek
SoCal
Interesting project.
Do you have a NanoVNA?
If not, what other test gear have you got?
What LNA are you using?
Also what's the end goal?
Have you tried using it for what you need as it is?
CYUL
Montreal, Canada
Right now I have an LNA that is tuned for 1090 ADS-B, nothing for 1.5. Also, no test equipment other than a couple of SDRs and my Icom receiver.
thebaldgeek
thebaldgeek
SoCal
Have you tried using it as it is?
It might do the job well enough to get you going?
