antenna help
johndeerefan
callao va
i just got a bc350c and i live in an apartment i want to pick up more freq and better i heard about an antenna called snoopscanner antenna can any one tell me one better for an apartment
jbantennaman
Banned
What I would suggest is that you buy a outdoors antenna, due to the fact that you will probably loose 6 db or more of signal just through the walls of a regular stick built home.
A steel reinforced concrete building would be even worse.
You could recycle a old television antenna that is made to receive UHF since many of the signals are on the UHF side of the frequency's.
