i just got a bc350c and i live in an apartment i want to pick up more freq and better i heard about an antenna called snoopscanner antenna can any one tell me one better for an apartment
What I would suggest is that you buy a outdoors antenna, due to the fact that you will probably loose 6 db or more of signal just through the walls of a regular stick built home.
A steel reinforced concrete building would be even worse.
You could recycle a old television antenna that is made to receive UHF since many of the signals are on the UHF side of the frequency's.
Check out the Wiki for info on antenna's Category:Antennas - The RadioReference Wiki Great source for info. You can do better than that one, like FLRAILMAN stated it has been listed in several threads in the past.
