Ham TX H/H as Scanner?
I have to sorta agree and disagree with KF4LNE on the use of a ultra Wide-Band H/H for scanning...
I use my Yaseu VX-2R a lot for scanning the local Ham frequencys, some local So and PD, and to monitor it's capabile frequencys occasionally.
The recieve circut of the tiny VX-2R is AMAZING in it's clarity and squelch. The broadband recieve capibilitys exceed all of my RS and Uniden Scanners. Recieve with a PRYME (SME) RD-8 antenna, is excellent!
However, the radio has one fatal flaw... it is NOT a Scanner, rather, it scans it's memory banks(the ones you enter in specific "search banks") top to bottom or visa-versa. It scanns the entire pre-programmed band the same way.
Contrary to a traditional Scanner, you may set the radio to stop on recieved signals, at pre-set timed stop periods but unless you MANUALLY halt it on a frequency, it then continues on its Memory scan timing (ie; 3, 5; or 10 second, intervils). It does not automatically stop and "hold" untill recption ceases on any specific frequency.
Granted this is a minor grievence, but you must stay on top of it and manually stop it, otherwise it works just great! Hell, I love my VX-2R!
A little point you might want to consider tho...
Dave13
