Antenna identification.
1BillyBob1
I am trying to figure out what type of antenna (up against the rear window) is can anyone help? 458107308_1156971692523285_4270483543755861403_n.jpg
nokones
Sun City West, AZ
My first guess is it is a combined GPS and LTE antenna for their MDC system or a multi-band antenna for an APX type multi-band mobile radio for radio interoperability with allied agencies statewide.
PaulSWIdaho
Boise
Looks like the old fashioned "inverted F" that metro busses used to use. They used that at rather low FREQS, high band in those cases where they did not want a tall antenna as a 1/4 wave would be too tall. They are rather wide band considering how short they are. They are wider bandwidth than a helical of the same height would be.
I'm guessing this only because it's low height and long front/back. Here's what the inverted F schematic looks like:
iu
nokones
Sun City West, AZ
I believe the California Highway Patrol (CHP) also run the same type of antenna and based on the other antennae mounted on the car and they were easily identifiable on what they were for, that left GPS and LTE for their MDC (Data). The CHP used to run the hockey puc antenna for their GPS and LTE for the MDCs. The manufacturer of the hockey puc style antenna may no longer be available.
GSP migrated to LTE on SouthernLinc for their primary communications, using LMR radio as backup. The antenna is very likely used for the LTE connection from the Harris radio, along with GPS for location data.
Many of those antennas will support multiple radios, so possible it's also used for their mobile terminals.
As for exactly which brand/model, that would take a lot of searching...
Golay
I'm thinking you do a lot of installs. It's my understanding some of the PD's around me have dashcam systems that automatically download video over the air to a server or whatever at the station. No touch automatically. If you're familiar with what I'm talking about, would you share a picture or two of what those antennas look like?
Thanks.
Thanks.
We have that, but the antennas are built into the recorder package. Not an external antenna on the vehicle. We've got a couple of wifi access points near where the cars are parked and they just upload when in range.
