CookeCityScanner
I have an antenna here with a PL259 connector on it. I will attach pictures. It almost looks like a cb antenna but there is an identical length whip (rod) dropping from it at a 45 degree angle. I have an idea what this antenna was originally for but would love some input. Also if you look at the pics I dont see how at all the rod which drops at a 45 angle connects to or effects the vertical rod. The vertical rod seems insulated to the connector and if it isnt then that means that the whole unit, u bolts, mast and all would be part of the antenna.
One more question The cable on it is RG8U from RS which is pl 259 connectors. It is slightly different than other pl259s Ive gotten though. The RG58U pl259 has a taper at the tip of the conductor while this stuff was one solid size. It seemed harder to get on as well.
