I use 2 Radio Shack 20-043 discone antennas. Both are mounted 15 feet high. I need to move 1 and the best place for a sturdy mount will put it at the same height and 10 feet away from the other. Is it going to cause any signal problems with the antennas being that close to each other?
Also, the new location will put it about 6 feet above the edge of my ( /\ ) tin roof. This antenna is mainly used for 800 MHz digital trunk system. I've read the tin roof/chimney mounting threads and it looks like it should be alright. Yes/No? Thanks
