If you connect the mounting point to the tripod it should work well. If you connect any other part of the antenna to the tripod it probably won't work that well. The tripod is just a mount, like a pipe - no different.uzma said:But wat if i buy a sepearate tripod and place the antenna over it ?
KC8JPZ said:That would mainly depend on what frequency you are transmitting on. The higher the frequency the better off you are for low placement of the antenna. What frequency are you planning to use?
Al42 said:DC isn't a very high frequency.
