To anyone looking to acquire commercial radio programming software:
What do you guys use on modern cars these days?... The last car I mounted an antenna on was an 80's boat where there were 100's of places to mount.. Now I have a 2001 Hyundia Elantra.
Usually we use something called NMO mounts. Stands for "New Motorola", even though it is many decades old.
It requires a 3/.4 inch hole, but if the mount is installed correctly, it is waterproof even with the antenna removed. Very strong and it does not require the removal of the headliner for installing.
I have allways had good luck with a mag mount Like a Wilson 1000 or 5000 a k40 I just like how easy it is to take off and put back on .I have never had a issue with TX or RX I know I am gonna catch hell for it but hey I never liked them tall antenna's just my 2 cents
NMOs all mount from the outside. The problem is running the coax, if you can get a snake up to the antenna mounting hole then you're good. Otherwise you will have to drop the headliner down to run the coax.
I have done several thousand NMOs. 4 alone on my truck.
Usually, you just have to access (or see) the underside of the metal. just uno the trim and shine a flashlight under the headliner. You can also just pop out the dome light and go right underneath it.
Once the hole is drilled, just snake the coax through the hole with a fish wire or bent antenna whip. once it is beyond the headliner, run it under the trim and button the celing back up.
Fords and Chevys are the easiest. Nissan isn't bad. Same for Dodge. I can have an NMO mount placed and installed from start to finish in under 15 minutes on those vehicles. Audi (or any of the higher end cars) are total murder to install. Those can require the headliner removal and take hours.
