firefighter331
I'm a member of my local fire department, where we have this airboat equipped with a dual band radio. It may be hard to see in this picture, but the antenna is mounted toward the front, right in front of the cab.
Transmit quality is not great on it. Since it's a fiberglass boat and that obviously was the issue, the department bought a ground plane kit for it, which helped a little, but it still barely hits a repeater that's only 93 feet away.
My question is what if I run a wire from the circular part of the ground plane kit, and ground that to the battery. Will that help? My thinking is that it probably will, since all the metal on the back end is grounded to the battery, therefore it should give it a better ground plane and improve transmit quality, right?
Just my thinking on it. Please correct me if I'm wrong, and I'm open to whatever other suggestions you have for it.
