modrachlan
I've thrown a random wire- about 100 ft- down the yard for in a east-west orientation with the idea of experimenting and eventually setting up a permanent longwire antenna. Attaching it to radios- clipping it directly to the whip, or wiring the lead to the center conductor of a variety of connectors, e.g. 1/8" mono jack, 1/8" stereo jack, and PL-259, results in overloading- everything from a Tecsun PL-310 to a Lowe HF-150. All across the spectrum I hear a strong local AM station in the background. So I'm trying to control that.
I've made a few changes. Stage one: buying a 9:1 unun kit and mounting it in a box, then driving a copper pipe into the ground, clipping that to the ground wire of the unun, attaching the long wire to the antenna lead wire, and running the receiver wire to the radios, clipping and plugging, etc. No improvement. Stage two: adding an active preselector in an attempt to suppress the AM station. No improvement.
Now, here's where it gets weird, or I betray what little I know about antennas. I was testing the longwire at the opposite end- I wanted to see where the performance seemed best: at 4 ft (the highest I can get it for now), about a foot off the ground, or on the ground. (i've read about the grass longwire and thought I would give it a try to reduce noise.) On that end, I don't get any overloading when I splice the wire with a 1/8' stereo plug and a short lead soldered to the center conductor. (the height test seemed inconclusive- sometimes 4 ft was better, sometimes on the ground was just as good as not). I did get good gain- almost as if I connected things backwards.
I followed the instructions for the unun closely, so I'm pretty sure it's connected to the right wires. I'm open to having done something wrong, though. I'm wondering just what the heck I need to do to suppress the strong station. I thought the preselector would make a difference, but really seems to make none at all.
If I am going about this all wrong and just need to do something else, by all means let me know.
Thanks for any insight.
