- Joined
- Dec 19, 2002
- Messages
- 2,135
I can identify all the signals I receive here in the VLF range. If you want to ID something around 30 kHz, let me know the frequency. I got rid of the frequency voltmeter I had when the battery failed--I have good SDR receive capability down to about 1 kHz anyway. For GHz range, I go portable/mobile or use my L-band dish/feed if it is space. By the way. my lowest frequency received was 30 Hz and leakage from the power line from the TWACS device (only would transmit a series of pulses a couple times a day. I had them remove the TWAC receiver they installed on my water heater due to inference from its CPU clock on the local 2-meter repeater (But the pulses on the power line of course remained).OK. Not sure what they use in the UK, but two antennas could be a mesh network system or cellular.
At one time there were a lot of analog video linking products that used 900MHz, so it was easy to dial them up and see what they saw.
Got it. I do the same thing, occasionally. I've got a remote receiver that will cover from 40KHz to 3.5GHz and it's fun to tune around and see what you can find, even if it's not something you want to listen to. I have a "frequency selective volt meter" designed for testing really old telecom circuits. It'll work as a receiver from 0Hz up to 3.5KHz. With a decent antenna, there's all kinds of weird signals way down in the 30KHz range. Up past 1000MHz, there's some stuff, but mostly wide band data that is using point to point directional links, or is pretty low power.
Aclara Demand Response Product Offers More Data, Greater Control
ST. LOUIS – September 8, 2008 – TWACS® (Two-Way Automatic Communication System) technology from Aclaraâ„¢, St. Louis, is known for its ability to perform demand response by controlling...
www.tdworld.com
