antenna problems
prophead
Hi all,
I have a Maycom ar-108 scanner that i have been using to listen to aircraft. I have recently bought an external antenna and mounted it on the roof. The thing is i cant pick up anything. not even the stuff i can with the rubber antenna that came with the scanner. I have tried it on the local moors before i fitted the antenna and it worked fine there. It also worked fine all the way home in the car until i was on my street. With the rubber antenna i get a signal strength of 5 and pick up the local airport. with the external antenna i get a full signal strength but just white noise. There is a large transmission antenna on the hill above my house which looks like an electricity pylon bristling with aerials and dishes. I presume this may be the cause, but then why is the rubber aerial ok. If this is the cause is there anything i could get that would block out that interference.
Regards
Prophead.
fourwd1
Socialist state of MD
Could be the proximity to the tower coupled with the added signal strength of the external antenna is overloading/desensing your receiver.
You in the UK ?
