Davejb
I have a Pro 2096 and listen to a range of around 150.xxx to 465.xxx, no trunking, some digital. I recently installed a new Scantenna in my attic (about 15 feet up, I know it's better off on the roof but not an option right now). Even with it in the attic I would think it'd be better or at least equal to the stock telescoping antenna that came with the scanner, not so however, the stock antenna works quite a bit better. Only thing I can thing of is the cable routing, it runs up inside a hollow beam along with some house wiring. Anything I can use to sheild the antenna cable or do I need to look somewhere else for the problem.
