I have a basic understanding of antennas but the theory side of it is over my head.
I have a Tecsun PL-660 on order & my intention is to setup a temporary long wire antenna.
I will be aiming at frequencies between 3 & 17MHz.
Because of limited space it will be restricted to about 16M (50ft)
It would be 16 AWG insulated braded wire & run approximately East West.
One end attached to neighbors’ carport & terminate on my house roof.
Then approximately 5 M of RG58 or similar, into my man cave.
Question:
Should I have some sort of device (UnUn, Balum or Transformer) between the receiver & antenna?
Following this, as a project I would like to build a magnetic loop antenna to replace the long wire.
I have looked at loads of variations on the net & read through the wiki etc.
However my limited knowledge means I would have to follow someone else design & hope it does what I want.
But the variation of design & components make it difficult to decide which one to use.
I have attached a couple below which look simple enough for me to build.
Your comments or advice would be appreciated
https://www.youtube.com/watch?v=ehjKrJ-TH_w
http://www.kr1st.com/swlloop.htm
Question:
