Antenna Question....a bit weird.
Brasso
Huntsville, AL
I want to put an antenna in my attic. It's just easier and I only need to talk local. Question: What would happen if you stuck a 102" whip into a Wilson 1000 magnamount on top of a ground plane? Would it work or is there something in the mount itself that would kill the swr?
KB4MSZ
Billy
Tampa, Florida
The antenna loading coil is designed around the 62" whip that is supplied with the assembly, it needs the values supplied by this whip in order to tune. I doubt the hole in the coil assembly could accept the diameter of the 102" whip anyway.
slowmover
Fort Worth
You’ll find discussions of “attic antenna” which will give context.
