Antenna question.
airboss1634
I purchased a motorola NAB6064B to replace a damaged antenna on my MT1000, but the old antenna is only damaged at the tip. I would like to know if it is possible to cut it down to work on my UHF Radius P110 that uses the same MX style base. It would look much better than the long flimsy antenna that is on it now. My question is can it be used on the P110, and to what length do I cut?
cmdrwill
So Cali
Those portable antennas for the low band VHF range have to be cut or 'tuned' to the proper frequency.
airboss20
Horseheads, NY
Antenna tuning.
I am aware that it has to be tuned for the freq. I was curious if anyone has info on what length to cut the antenna for the uhf band. The low band antenna coil is larger in diameter, therefore, I think there will be a variance in the length for the uhf band. The specific freq I am interested in is 453-469. Any information would be appreciated.
cmdrwill
So Cali
You need the UHF antenna which is a 6 inch whip style molded.
NAE6350A is the correct Motorola part number.
DPapay
Morris County, N.J.
It may be possible, however the antenna was not made for that freq range. You would be just guessing as to the length. It probably would not radiate very well either. You can get a stubby antenna for that radio though.
