I work for a newspaper in Concord (Cabarrus County). We're using a RadioShack Pro-106, and I just hooked up a TerraWave Solutions 806-960 MHz Yagi Antenna.
I have a couple of questions to determine whether I'm using the system correctly
1) I have the antenna pointed at the tower in the center of the county, represented here: WPGT418 (CONCORD, CITY OF) FCC Callsign Details
I don't know that much about the system, but it's called a simulcast. Can I get traffic from the whole county by pointing the antenna at any tower?
2) The antenna is currently inside my building attached to a coat rack. This is a temporary solution, but the boss is talking about putting it on top of the building. I've read about signal loss over cable distance. The distance between the scanner and the antenna will be 50 feet or more, whereas now it's about three feet. Is this a problem?
3) I have the antenna angled parallel to the ground. Should I angle it up, since the tower is 90 feet high?
