Ok thank you. Can you terminate it with an RG6 connector and adapt it to bnc for the scanner end?Yes.
So are we talking about 20 ft or are we talking about 120 ft LOL.Can you use RG6 cable from the base antenna to the scanner?
RG6 is easier to work with and the loss is only a couple dB more than LMR-400 at 40 ft length at 800 MHz (I use both types). It is true the impedance of RG-6 is 75 ohms. That mis-match is generally less than a 1 dB loss. Also, most scanners are not exactly 50 ohms anyway (in fact, early scanner antennas, when you used to get cable with them, usually came with 75 ohm cable)--the truth is, you would be hard pressed to tell the difference for runs you are considering. For longer runs and higher frequencies, of course LMR-400 would win out. It is best to buy quality RG-6 if buying RG-6/ This subject gets argued hear yearly...Can you use RG6 cable from the base antenna to the scanner?
If you search RR you will find lots of posts where people have changed from RG-6 to LMR400 and noticed a big improvement.RG6 is easier to work with and the loss is only a couple dB more than LMR-400 at 40 ft length at 800 MHz (I use both types). It is true the impedance of RG-6 is 75 ohms. That mis-match is generally less than a 1 dB loss. Also, most scanners are not exactly 50 ohms anyway (in fact, early scanner antennas, when you used to get cable with them, usually came with 75 ohm cable)--the truth is, you would be hard pressed to tell the difference for runs you are considering. For longer runs and higher frequencies, of course LMR-400 would win out. It is best to buy quality RG-6 if buying RG-6/ This subject gets argued hear yearly...
There are ways to get around the clumsiness of using LMR400. Bring it to a table top leg, and tape it with Gorilla Tape and then do a short jumper to the radio.RG6 is easier to work with and the loss is only a couple dB more than LMR-400 at 40 ft length at 800 MHz (I use both types). It is true the impedance of RG-6 is 75 ohms. That mis-match is generally less than a 1 dB loss. Also, most scanners are not exactly 50 ohms anyway (in fact, early scanner antennas, when you used to get cable with them, usually came with 75 ohm cable)--the truth is, you would be hard pressed to tell the difference for runs you are considering. For longer runs and higher frequencies, of course LMR-400 would win out. It is best to buy quality RG-6 if buying RG-6/ This subject gets argued hear yearly...
Great guys to deal with.Antenna Farm
Yes and the higher you go up in frequency like GHz’s you don’t want to use adapters because it creates loss. And it does effect receiving the higher you go in frequency. At HF it doesn’t matter, at VHF, I wouldn't loose sleep over it. UHF and above, I try to keep the run clean of adapter.You can purchase BNC connectors that will attach to the RG-6.
Or, you can get F to BNC connectors. It's usually better to use the correct connector rather than use adapters, though.
I have found the AOR MA500 mobile whip antenna about as good as any for wide band scanning.Another antenna question, for car antenna ….. in my area they use low band up to 800 MHz. What is. Good antenna that will pick up all those bands?
