Antenna Questions
senduhelp
Mechanicsburg, PA
I live in a 2 story townhouse and am hoping to put a simple magnetic mount scanner antenna outside of the 2nd story window to increase my reception. I was just curious of any suggestions as to the best way to go about this. I am hoping to have one that is not outside permanent, but one that I can only put out when I am using it. I am also open to suggestions if there is an antenna out there that would be better for doing this instead of a magnetic mount. Thanks for any suggestions.
LarrySC
Greenville, SC
I have a spare BC-9000/PL next to the wifes easy chair. She didnt want connected to my antenna farm so I cut 56" piece of hookup wire with an alligator clip and put it in behind the window curtain. No coax loss and no connector/adpator loss. Receives better than you think. A friend of mine used burglar alarm tape on a window. Cut VHF/UHF/800 strips and tied together. He said hookup was not that hard. Drop the 56" wire out window with a fishing weight on the end. I could tell you about using a coat hanger, but you would never beleive it. Good Luck.
ReceiverBeaver
Banned
Hi SUHelp,
I take it you realise that your magnetic mount ant. is a Ground Plane type ant. and will need to have a metal-based something or other under it to be the ground plane. When put put on a vehicle, the metal body of the vehicle is the ground plane. Sitting on a table by itself you're looking at only half of an antenna. Any sufficiently large metal structure will work. Many folks stick mag mount ant.'s on top of a refrigerator/washer/dryer ect.... I 've used a unturned 55 gallon drum with good success. Or there are iron deck railings. You simply must provide a ground plane for a ground plane type antenna that doesn't come with its own radials....like base station ground plane antennas do.
Otherwise, do what the other fellow has suggested and just put a 50 something inch piece of wire in the antenna port and string it up vertically. No coax. It will work nicely for receiving only.
Good luck!
senduhelp
Mechanicsburg, PA
Thanks everyone for your help, so let me just make sure I understand all of this. If I wish to use the magnetic mount I have to have it sitting on something metal, I knew that part however does that something metal have to be something that is sitting on the ground or can I just put say a piece of metal on a board and sit the antenna on the metal out the window.
In case # 2 if I wish to use the piece of wire, do I just run antenna wire into the antenna hole on the scanner. Sorry if I am sounding stupid on the topic, I have never tried to use any antenna other than the one that came with the scanner. Thanks.
xusmarine1979
Louisville, Ohio
When I was younger my mom gave me one of her cookie sheets to place a magnetic mount on it and it worked really good. It depends on what kind of antenna mount you have for the wire antenna.
USAPatriot
PRK
Another option would be a premade length of longwire. Radio Shack probably has it. It's just a BNC connector with about 12' of insulated wire attached. The first 4 feet are RF opaque, the remaining 8 feet are the actual antenna. You could literally toss it out the window and not worry about it. Probably not as good a ground plane mag-mount but neither solution is going to be top notch given the constraints. -Rod-
N
N_Jay
Guest
Wow, RF opaque wire!!! Must be a cool color! :confused: :confused: :evil:
N
N_Jay
Guest
USAPatriot said:
Mmmm. Black insulation and shielding :roll:
And the shielding is only "shielding" when the impedance of the system is matched, which is highly unlikely.
USAPatriot
PRK
Only bought it and used it, Jay...
