USAPatriot
I had a thought. (Been one of those days, but it does happen on occasion)
One of the banes of scanning reception is signal loss due to coax length and other factors. Fact is, ya want better reception you go up higher. And sometimes the mast/tripod/tower placement isn't exactly optimal with adds even more length to the coax and inevitably more signal loss.
So why not do away with the coax? It seems to me that under certain circumstances everything collected by the antenna could be rebroadcast wirelessly, in essense a wideband repeater. I'm not tech enough to know the pitfalls though the more obvious ones do jump out at me: noise from rebroadcasting the entire spectrum. A jamming effect from the rebroadcast interfering with the collected signals (Seems like the rebroadcast would need to be either much higher or much lower in frequency than the collected signals in order to avoid that). One could probably amplify the signals as well but there's obvious problems there too.
Still, it might be worth it all if it was cost effective and managed to leave the user better off than if he'd been using coax.
Thoughts? -Rod-
PS...I have NO idea if this has already been tried or already been done. Was just pondering my own upcoming signal loss problems.
Thoughts? -Rod-
