russellv2
Question for input from those in the forum:
Is there a good formula based on frequencies or wavelengths or something similar to find interaction between two antennas mounted a distance apart?
To illustrate... stemming from the dual rubber-duck antenna question that was posted here earlier. If I have a 440MHz antenna and say... a 2m ham antenna mounted 24" apart, is there a way to figure out what interaction those two antennas would have on each other?
Transmitting power probably works in there as well if they're transmitting antennas, but if they're just Rx... I'd be curious to know if anyone has input. Thanks.
