Antenna speaker mic (MC-023933-002) for the XG-75 - use for mobile antenna quick disconnect?
Thunderknight
Bletchley Park
Any thoughts on using the Harris MC-023933-002 speaker mic on an XG-75 for mobile antenna use? This is the mic with the RF jack.
Meaning, instead of removing the radio antenna and threading on a vehicle antenna/adapter, I would leave the vehicle antenna connected to the mic and then just attach/remove the mic from the UDC. Basically a quick-connect external antenna.
I'm assuming since the RF connector on the UDC pushes in, it disconnects the radio antenna when the mic is plugged into the UDC.
(This is not a public safety application)
(And too bad Harris doesn't make convert-a-coms like Motorola does)
K2NEC
I guess it's worth trying out. Never know, you might be surprised
And Harris DOES make convert-a-coms just not for the XG-75's. They make them for the older P7100/P7200
