Be happy to, 1st off I'm no expert, that being said, seems the antenna shaft it's self is some sorta stainless alloy, and the bottom part of the antenna shaft that the little 5/16 wrench fits on to tighten the shaft to the black base coil, my friend who a machinist says it looks to be nickel coated brass, that is pressed on, not threaded, if a person could get that off and was lucky enough to locate a micro choke, then yead i would think a person could make a mon52 out of a none micro choke model "mon33" ect, i have had NO luck at locating a micro choke. A person could have a choke made, but I'm not going to that extreme, especially sence i agree with my friend, that bottom piece is a press fit not threaded, if anyone can add more please do, hope this helps, I'll try and post some images soon.
