Most scanner are designed the same way. There will be protection diodes that perhaps can handle up to a 1/2 watt of power, then they will blow and go open circuit and usually are blown off the circuit board if the power are high enough and stops protecting. There are bandpass filters for each frequency band that are enganged by forward biasing switch diodes. If the filter pass the frequency that enters the antenna port it will go straight to the first transistor and damaged it. Perhaps only partly so it will not have full sensitivity and will have lots more interferencies.
When a scanner are powered off all filters will be disengaged and will not pass any signal at all. But if the power coming from the antenna port are high enough the switch diodes will start to conduct from the peaks of the frequency wave. There are switch diodes both at the start and at the end of the bandpass filter that will need to conduct to pass any power. The bandpass filters have an impedance so the diodes at the end will have a series impedance that requires a higher powered signal from the antenna port to start to conduct. There are also diodes that will start to conduct that will direct the signal to ground.
When a scanner are powered off it will be much less damage from high power signals compared to when it is powered on. Always turn scanners off when not in use to reduce damage from voltage spikes from nearby lightning strikes and transmit sources. Hopefully only the two protection diodes at the antenna port will blow but you will be oblivious to it as the scanner probably works as normal but there will be no frontend protection at the next high power encounter .
/Ubbe
