The SP-1300 looks like it is just a standard CATV splitter with BNC connectors. It may be no different internally.
That being said, many people use standard CATV type splitters and never have an issue. The problem with them is that most provide no isolation between outputs. This can cause interference issues with some scanners (and could even damage sensitive electronics).
The best way to go is always to use a quality multicoupler, but they are expensive (not always worth it unless you're using expensive scanners). But the bottom line is; you will probably be fine with cheap 2-way CATV splitter (same thing they sell at Lowes, Home Depot, Radio Shack, etc). To minimize loss and reduce cost, use F connectors on your coax cables (don't waste money on F-to-BNC adapters).
Good Luck and Happy Scanning
