I've been doing some antenna testing and on VHF/UHV 800MHz using the SRH77CA(2m/70cm), RH951s(2m/70cm/1.2Ghz). This is what I have found out here in eastern North Carolina (Carteret county) that the RH951s has the best all around receive in VHF/UHF and 800MHz by one to two S units in doors outside about the same. The SRH77CA does well on the scanner a little low on the 800MHz but does receive it. Thanking about trying the Austin Antenna and a Max Systems 8HH Antenna (800MHz)
What antennas have you tried?
