Unless you are using a small super inefficient antenna where you are actually starving the receiver for signal, using an antenna tuner will not improve your signal to noise ratio. Bringing signals up 6dB with a tuner means nothing unless you can improve the SNR.
One S unit are 6dB, so 400% stronger signal. That's good enough for me. I have a tuner never unboxed since 10 years. Maybe I should try it if it will give me that kind of improvement.
/Ubbe
