Antenna under a steel roof ok?
KF0AWL
Hobo
Iowa
I was thinking of setting up a radio room on our second floor.
The thought crossed my mind I could put the antenna up in the attic access in the ceiling.
My question is tho, we put a steel roof on last summer will that interfere with a attic antenna or even a outside antenna?
I know a steel car will interfere so that's were my thoughts
KF0AWL
Hobo
Iowa
That's what I thought.
My radio room is set back a bit behind the front (kick out from the house) also so I'll need to place my pole outside the footprint for better reception to I'm thinking?
KF0AWL
Hobo
Iowa
Ok this what I'm working with. The window over the porch would be my radio room.
If I put a antenna on the porch roof would the steel siding effect my transmit and receive? Or would I be better putting a pole mount at the edge of the house?
I'm not really thinking of a huge antenna up. More so a tripod style base n med height antenna.
Just kicking around thoughts for future plans.
LATA 722
You'll need to have the antenna above the roofline. Anywhere below the roofline and the metal roof will act like a big reflector and make your antenna directional, as well as block most of the signals from the other direction.
Mount off the gable end and get your antennas a few feet above the roof.
W5lz
Very simply, the top side of a metal roof is okay to mount an antenna on [a vertical antenna]. The bottom side is not.
