lonlywolf65
- Joined
- Feb 4, 2020
- Messages
- 134
Hello all.. I hope all is well . I will start with the fact that I am a newbie to this, there is alot to learn..
I purchased a cobra/uniden roadking it comes with a 24 inch mag mount antenna, most likely about the worst a person could get but will work sort of for now...
I am working with a tight budget for now but still trying to do an upgrade. I have a 4 ft fiberglass antenna but no mounting hardware.. I have checked continuity and all is good there.. I am looking for advice on the best way to use this antenna for now ... My thoughts are to get a ground plane kit for it and some RG-8 coax .. and some way to ground this this...
I have been windowshopping all sorts of options, but figured I should present my situation to those with more knowledge than me. I understand this will not be a great upgrade but it should be better that a mag mount on a pizza tin sitting outside..
I went outside tonight and looked up where I will be mounting the antenna and realised that I dont have alot of room to work with. I have a aprox 200 yr old Oak tree hanging over the mounting area.. so not alot of room to work with.... Another note I'm not sure if the city owns the tree or my neighbor.. another story but I cant do much about the branches.
I figure I will leave it at this for now untill I get more info... Thank you all in advance for the help and advice I already know there is a awesome group of ppl here thank you!!
