Like hfxChris indicated, how long does the cable need to be, but also several additional facts are needed to provide a proper answer. What frequency range(s) are you looking to use? How much do you want to (possibly even are willing to) spend? How "handy" are you as far as doing the installation (both the stringing up the cable as well as installing the connectors)? Have you planned your lightning protection and if so what kind of connector does it use? What kind of connector is used on your antenna (probably UHF/PL-259)? What kind of connector is used on your scanner (a Pro-106 has BNC)? What amount of coax loss is acceptable for your needs?
As you can see, there are many factors that need to go into answering your question correctly. A simple answer would be to assume the worst and pick a very expensive, hard to install cable, but one with very low loss and say that was what you need (perhaps this
Heliax Coax). Another simple answer would be something small, cheap, and easy to install (like
RadioShack® 50-Ft. RG-58 Coax Cable Assembly - RadioShack.com). Either might do the job, but could require adapters, be way too expensive for what you need, or have too much loss to get the desired signal from the antenna to your radio.
A great suggestion for a feed line on a very low frequency and short length might be the worst thing you could use for much higher frequencies and/or longer length.
