Cool ~ thanks for the advice.
<Snip>
The question: am I correct in assuming this is simply the wrong antenna for my scanner?
not bad , not wrong , but not the greatest either
receiving radios like your scanner , will work regardless of what type of antenna
is connected to them .
transmitting radios , are much more particular , you need to have an antenna
that is "resonant" or you could damage the radio with reflected power
that is what "standing wave ratio" is a measure of .
this is not an issue with receiving radios
however , a cb antenna , will not perform as well at 800 mhz , as say an antenna designed for 800 mhz
as a cb antenna is designed for 27 mhz
there is no "perfect" antenna that will cover every band with gain and bandwidth
a scanner simply covers too much spectrum for that
so if you want gain and bandwidth , then you will have to consider several different antennas
its already been suggested , that you should look at a discone
they don't really exhibit any gain , but they cover the whole spectrum that your scanner
does .
just get it up as high as you can , use a quality coax rated for 800-900 mhz
and forget about it ,
if you want to split hairs , and have the ultimate in gain on every freq . then you will be looking at
a vast array of yagis , quads , Quagis , etc, and a huge bank of rotors to turn each one
the other thing you must consider is that you simply wont be able to receive
anything over your horizon ,(usually about 50 miles on flat land)
on a daily basis
this is simply the nature of digital and fm signals . they are "line of sight"
occasionally though an atmospheric conditon called "Tropospheric Ducting)
occurs and then you could hear police calls from a thousand miles away or better
still though , it wont matter what type of antenna you are using when this occurs
bottom line , your cb antennna will work great for freqs between say 27 and 34 mhz ,
if your using it for receiving , but as you go up in frequency , its resonance falls off
and it becomes less efficient , but will still provide a signal to your scanner
a little long winded , but wanted to make sure you understood that
there is no "perfect" antenna ,
there are trade offs and compromises ,
again , DISCONE !!!!!
Google is your friend
73
