dragon3158
i use the radioshack pro 164 in MA an i wanna hear stuff further away. i was thinking of getting a bigger antenna. i was thinking Outdoor VHF-Hi/UHF Scanner Antenna...
If you're using the "rubber duckie" antenna on top of the 164, you will surely increase your reception range by stepping up to an external antenna, but some additional info is needed.i use the radioshack pro 164 in MA an i wanna hear stuff further away. i was thinking of getting a bigger antenna. i was thinking Outdoor VHF-Hi/UHF Scanner Antenna...
Yes and no.is there a way to connect one anntenna to two scanners at the same time?
No.....ok well im only looking to hook one anntenna to 2 scanners..is it somthing i can get at radioshack?
