Dusk hit just as I finished the transformer so I rolled out all of the wire, about 67' and did a quick sweep. I still need to add the pull lines and the chalk rollers. I used 25' of some BNC cable I had, so no choke yet for TX. I mainly wanted to see the numbers and wondered how much I would need to roll/cut on the end of the antenna wire, or if I had fudged something.
For now, it appears my single mistake was not drilling the hole for the antenna wire closer to the corner. That plastic box is more durable than I thought. In fact, I re-drilled closer to the corner and everything fit and did not get wonky. I now have a passive vent. Also, no silicone yet, as I was testing. I'll probably keep using the Velcro to close the case as tape leaves a residue.
The wire was only about eight feet off of the ground on each end with the following results. I obviously need to test with it elevated at different heights and see what's what. 40 meters was the most narrow, but the SWR was fine across the band. As you can observe on the sweep 20, 15 and 10 meters had more bandwidth. The numbers are the lowest for each band and mostly hit center on each.
I'll update once I test at different heights, both slope and horizontal configurations.
[ Click an image to enlarge ]
