Antenna's What are useing?
ghostdog
UCAN County,UT
I Was wondering whar kind of antenna's you are useing for portable scanner's i would like too get a better one
thanks ghostdog
bchris
Salem, Utah
I was wondering what kind of antennas you are using for portable scanners. I would like to get a better one.
thanks ghostdog
I use the 800Mhz antenna from Radio Shack. Lots better than factory for UCAN stuff, still OK for everything else. There are probably better ones out there, but for $20 and the convenience of buying local, I have no regrets.
I also have the little tiny 450Mhz 'racing' antenna from RS. Not quite as good for UCAN but still pretty good, and the scanner fits completely inside my pocket.
--Brent C.
gldavis
KE7MQF
Bountiful, UT
If your wanting UCAN, then I agree with the Rado Shack 800Mhz antenna. For other freqs/bands, I prefer the Condor antenna. It has good "all around" ears. At times, I will use band specific antennas when concentrating on a band.
