Anthem Blue Cross and Blue Shield with Securitas inc.
nofdexplorer406
Bedford, Kentucky 40006
I just Recently Started Working for Securitas Inc. I am posted in the Anthem Building at Gene Snyder and Old Henry Road actual address is 13550 Triton Blvd. The Radio system is crap they are old, cracked, messed up modulations, ripped out antenna, etc. I was wanting to know where to locate the freqs for it. I looked in the Database but found nothing. All i Know is UHF Range they are using Brick Motorolas and we have a few screwed up TK-370's. And the bad part is they are not PL'ed we get so much interference its crazy. You think for a high priority building and a High Security company it would be better equipment. Myself and A senior officer are wanting to hunt down the Freq info to buy our own radios so when we are on shift we got good crap that belongs to us. I know we have alot of listeners and scanners in Louisville so i would appreciate the help ima try to get ahold of a scanner all i got is a VHF Fire Kenwood TK-250 160 channels
Here is the Facility 4 stories with roof, state of the art 360o cameras inside and out magnetic cards and master keys put it this way i got Jefferson County Fire channels in my VHF two way and it wont pck them up that close to the tower but once i step out side crystal clear
jerk
jerkville
I think you need a frequency counter. They are probably using someone else's license or are unlicensed.
And if your not sure on the frequency, I was thinking they may have operations on the Louisville Two-way trunking system. There are several security outfits on it.
nofdexplorer406
Whats a Frequency Counter never heard of it before. I was looking at a old hunk of junk on the 12 i just pulled and it said Radioland so that sheds a light on the programmer. ill look into the trunking people but its for sure UHF. We ran into so many radio problems tonight mics were not working, batteries dieing every few hrs, ahh its a never ending list. I work thursday with the Site supervisor so i will try to see what info he can give me also ill try contacting radioland but i probably wont get any info from them without approval and clearance
jerk
jerkville
It detects frequencies, basically, radio transmits, frequency shows up on the Counter.
The Uniden BCD396t has a simple one built-in
Radio Shack used to sell one, they are on ebay.
Radioland also has a LTR trunked system in UHF range, but most likely simplex UHF, do you talk to a "dispatch" on these radios, or is it just building to building use. And how many channels on the radio and what ones do you use. Also a model number would be extremely helpful on the Motorola's. Do they beep at you?
I'm thinking simplex or UHF LTR because of the Kenwoods.
nofdexplorer406
The Radios are used on site but im pretty sure from my own radio experience there are no pl's. they said on good days dispatch can hear you its farther away but we always check in with them by phone. no beeps simple key up and down no squelch either we have several Kenwood TK-370's with 2 channels, and several older Motorolas like they were banished 10 yrs ago thats how old nothing capable of newer technology. put it this way put a brick in your hand thats how old it is lol. I just dropped an email the the President of Radioland but im sure im gonna get a denied response from them.
jerk
jerkville
Be careful about that, they may decide to downside you.
OK 2 channels on the Kenwoods. Pull the battery again and see what the Motorola's have... Sounds more like simplex, but a model number on the Motorola's will really help.
This may help also.
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds.
Press and hold (light) & (dial) while turning on radio.
Hold until (SEL) appears on the display.
Pressing (SCN) allows you to program the following
1. Monitor Key
Off = off
1 = Monitor momentary
2 = Monitor Lock
3 = Squelch off momentary
2. Scan Key
Off = off
Co = carrier operate
To = Time operate
3. Dial Key
Off = off
On = enable
4. TA key
TA = talkaround
RV = Reverse
Off
5. Lo Key
On
Off
6. Priority
None
1 = fixed
2 = selected
7. Fixed Priority Channel
Turn selector to channel
8. Look back time A
Turn selector to time in seconds
9. Look back time B
10. Revert Channel
1 = Selected
2 = Last Call
3 = Last used
4 = Selected + Talkback
5 = Priority
6 = Priority + Talkback
11. Tx Dwell time
12. Drop out delay
13. Time out timer
14. Tot Pre-alert
15. Tot Rekey time
16. Tot reset time
17. Squelch Level
Turn selector to Squelch
18. Beep tone
On
Off
19. Signalling
And
Or
20. Battery Save
On
Off
21. Selectable QT
On
Off
22. Clr to transpond
On
Off
23. Del/ Add
On
Off
Pressing (Dial) allows programming of:
DTMF
24. digit time
Turn selector to time in milliseconds
25. inter digit time
26. First digit time
27. Rise time
28. Rise time with QT
29. PTT ID
Off
1 = connect
2 = disconnect
3 = Both
30. Dial ID
On
Off
31. Connect ID
32. Disconnect ID
33. # of DTMF keys on Keypad
12
16
34. DTMF hold time
On
Off
35. Store & send
On
Off
36. D key assignment
Turn selector to D or time in seconds for pause
37. Dtmf Signaling
Off
1 = code squelch
2 = Selective Call
38. Intermediate Code
OFF
A
B
C
D
E
F
39. Group Code
OFF
A
B
C
D
E
F
40. Auto Reset time
Turn selector for time in Seconds
41. Call Alert/ Transpond
Off
1 =
2 =
3
4
5
42. Transpond
On
Off
Pressing (TA) will allow you to program Frequencies
Use selector to choose channel
Press PTT
Enter Rx frequency using:
- the Selector Knob to change kHz;
- the Selector Knob + (light) to change MHz.
If no channel is Shown press the (LO) button.
Press PTT
Enter Rx CTCSS code
Press PTT
Enter Tx Frequency as above
Press PTT
Enter Tx CTCSS code
Press PTT
1. Option Signal
Off
1 = DTMF
2 = 2-Tone
2. PTT ID
On
Off
3. Add/ Del
4. Busy Tx
5. Clock frequency shift
6. Power
Hi
Low
Repeat for the other channels
(you've got a 32 channel radio, so it may take a while...)
<end>
Grog
Banned
West of Charlotte NC
The 270/370G version had to have the FPP option enabled in the software as well as having a hardware mod performed, the older 270/370 is likely the same way.
jerk
jerkville
Yes, it's probably not. But it won't hurt for him to try. And the more I read, the more I think these radios are nothing special, other than two-way conventional.
nofdexplorer406
I think one model is the SP 100 pretty sure but i go in for another 12 in a 1 hr 1/2 so ill write in the morning around 8:30. most of the motorolas are so old the have the squelch nob and a toggle switch for the channels lol. what do you mean they will down side me?
jerk
jerkville
Down size, also known as fire you. There was paramedic on the Ohio MARCS list who posted some information about the radio for his company. Just channel information and Alpha labels. They fired him.
I'm just saying be careful. Now they could be using a license from RadioLand, itinerant for Jefferson County. My rough guess would be 467.xxxx or 466.xxx range for frequencies right now.
nofdexplorer406
I Just got off a 12. We have the following Radios. 3 TK-370 G-1's, 2 Motorola Radius SP50's, and 3 Motorola Radius P 100's. Under the Battery on the P 100 it says 460 to 470 so that narrows the band down on the search and as old as the radios are it basically says its a freq no special tuning or coding or encryption. In my 12 hr shift i went through 4 batterys in the 370 i was using. if they fire me for asking a simple question of can i get the info or not i will hire a lawyer cause its outrageous that the security company can not get proper equipment to communicate on the premisis. Thats basically like sending a firefighter in a fire without info of the outside activitys of the fire. Im simply a good employee looking around a problem they have denied to fix
jerk
jerkville
Ok, it's a a simple radio system. That's the easy part.
Do you go through a repeater? And is the second frequency a talk-around frequency.
What exactly do you use the radios for? And are they in use during the daytime also.
Here are some possibles for a repeater use:
464.3250, 464.3750, 464.4250, 464.4750, 464.5250, 464.5750, 464.6750, 464.7750, 464.8250, 464.8750, 464.9250, and 464.9750
I'm thinking from the description it will be one of these.
And then from RR wiki:
White Dot 462.5750 GMRS 2
Black Dot 462.6250 GMRS 4
Orange Dot 462.6750 GMRS 6
Brown Dot 464.5000
Yellow Dot 464.5500
467.7500
"J" Dot 467.7625
467.7750
467.7875
467.8000
"K" Dot 467.8125
467.8250
467.8375
Silver Star 467.8500
467.8625
Gold Star 467.8750
467.8875
Red Star 467.9000
467.9125
Blue Star 467.9250
467.9375
469.5000
469.5500
nofdexplorer406
They are Used 24/7 at the facility. One Channel is Repeater but really crappy interference and the other channel is TA on the same freq. They are used every day for checking certain problems, ToCo rounds, Door Checks, Delivery Watchs, etc. From my experience with repeaters the repeater is not no where near the Premisis its probably located at the other Athlem building off hurstborne and I-64
So whatever it is its the same freq
nofdexplorer406
Grog
Banned
You do realize you are violating the trust your company and the people who contract with your company have with you, right? You are posting where you work, way too much detail into the comms systems. Hell, post the combination to the door next time and make it even easier for someone to walk right in.
kd4bas
Monitoring, Hanging Out, & --mn-@v@-mn-- you.
Morganfield, (Union Co) KY
nofdexplorer406 ,
Most companies that hire security companies like Securitas, use the radio system for that site. Every job site I have been assigned to has used the site radios. Currently at my site we are using the company (where I'm assigned) repeater for security and its barely used, we are more likely on the other 8 frequencies paging or passing brief information to HR, Safety or Shipping & Receiving.
nofdexplorer406
How Do you put a Kenwood Tk-370 into read mode if i was to try to read it with the cable and software. I know how to do the 360s and 350s just dont know how to do the 370.
