Antique CB Question
nydxa
Bergen County NJ
I'm restoring a Lafayette HB-444/25A from the mid 60's. I'm looking for the schematic, or actually the wiring for the AC line cord. Can anyone point me to a web site that would have this info or perhaps someone has the schematic and can tell me which pins get jumped and which ones get connected to AC power.
Many thanks
Bob
njscan@gmail.com
K4PS
Summerville, GA
Hello ............ It should be the 8 pin octal looking plug. If so, the 110 AC goes to pins 2 and 3. Pins 4 & 5 are jumped together.
Check out CBTricks.com and go to the Lafayette Radio's page. You can also get some good info off of the old CBTricks manuals that are PDF on file there.
Mike
Dawn
Pinecrest,Fl
Best to look on Ebay for a SAMS that is usually $12 or less shipped for used copy. Several vendors are constantly replenishing their stocks. Recently, the trend has been to drop the prices of the pre-40 channel units to prices around $7 or less unless it's a high demand manual. Same for 40 channel sets, very popular ones like for a 148gtl or 2000 will fetch more then $12.
Second option for Lafayette is Manualman's website. Pete carrys an enourmous amount of manual copies professionally reproduced at reasonable prices compared to many others. The difference here is he is a former Lafayettte owner/franchisee and has access to documentation that otherwise others would have.
If this set means much to you, it would be wise to pursue both a SAMS and original service manual even if you don't do your own service. I do restorations and this would be a major factor in me taking a job outside of the chassis I know and have docs for. SAM's while giving an annotdated schematics and alternate parts sources and an alignment procedure really offers little else such as theory of operation, circuit board xray views and other things that really assist a tech or anyone doing repair. A good combination is a copy of both to assist a tech or yourself.
While I don't reccomend this and it's best to find an Octal socket that was popular well into the 70'd particularly with American sets along with Jones plugs, you can cannibalize on old radio set using an old octal tube base. Worst case is you can use molex pins slightly spreade out with heat shrink tubing over them if this is a set you're going to keep and do the jump internally. That's a crapy way of doing it, but better then what's I've seen where people try to solder directly to the pins that presents a headache cleaning them up later if you do find a real connector. Octal sockets with a shroud should be easily found on Ebay or another cord for something else and rewired.
TheSpaceMan
Westchester County, New York
I remember when I got a new Lafayette Comstat 25 in 1966, the users manual contained a schematic for the rig. It may also have been included with the HB444/25A users manual, which was manufactured around the same time.
davenlr
North Little Rock, Ar
Man, I had Lafayette CBs and quad stereos (remember those? Discrete or matrix?) when I was a teen. Gosh I miss that brand. Always seemed to have the latest and greatest, worked well, and I could afford em with my paper route tips.
