I bought a new Antron 99 antenna and I can't get it to work. It is mounted on a 16' pole that is well grounded. I am using a 50' RG-58 coax. I bought a new SWR/PW meter from Amazon. I tried checking the SWR on a working CB. And in Forward, the needle does not move. Turning the adjust knob does nothing. So of course in Reverse, there is no movement on the swr needle either. I tested the swr meter on a friend's mobile and it worked fine. I checked the cable for open or shorts and the cable test fine. But to be sure (since it came pre-made with cheaper connectors), I replaced the connectors with good quality ones that are soldered well. And the cable still test great. But I cannot get no reading from the Antron! I tried various mobile units with a bench power supply and the same results on all cb units. The interesting thing is, if I put the PL259 connector anode into the CB jack, just the anode, I get reception. As soon as I screw it on (or touch the grounds together to screw it on), the reception dies to dead quite.
