Thanks for the Info. The Watson WSMA 801 looked like a great antenna at the right size problem is Scanner Master is out of stock I'm having them e-mail me when there back in stock. Most likely that won't be for awhile
. I'm ordering the Diamond RH77A even thou its made for Ham The price is right and If it don't work out maybe the Watson will be in stock by then. the majority of what I'm listening too is UHF with a couple of VHF's and 1 channel in the 800mhz range. The only thing I don't like about the Diamond is the size 15". The Comet while small would be the next choice while it did get some good reviews on amazon , some people have noted it it had trouble with medium strength signals. Thanks for all the info I'm sure there all better then the stock antenna which for me is ok pulling in some signals but its just not enough for the others which are not really that far away.
You may want to read this thread. It will do more to improve your UHF reception than a new antennaThanks for the Info. The Watson WSMA 801 looked like a great antenna at the right size problem is Scanner Master is out of stock I'm having them e-mail me when there back in stock. Most likely that won't be for awhile
Thanks for the Info on the RF shield tape on the back of the battery door I have some of that tape here at work and I'll give it a try Got to make sure you don't short the batteries I'll add a small piece of foam around buy the terminals.
I ended up buying the Diamond SRH77CA for the SMA connector. What sold me was in universal sales description they mentioned they sell more of these to Scanner Listeners then to Ham's We"ll see in a couple of days.
