Any chance we can delete the New Britain info?
n5ims
New Britain has been X2TDMA for almost a year now. Maybe we can delete the old info?
Generally most old information is not deleted, but marked as "depreciated", meaning it is old and not currently in use. If you have confirmed information that their old frequencies are no longer in use, submit this information so they can flag the frequencies as appropriate. Be aware that often an agency will keep their old frequencies around as a backup so even if they are no longer in active use, they may still be available and useable in their backup role and as such are still actually should be kept around.
cg
Connecticut
Probably a good bet that they are not going to boot up the old Motorola Type 1 system (which uses all the same frequencies as the new system)
chris
