tampatracker
- Joined
- Dec 9, 2007
- Messages
- 1,241
I like to see GRE develop something like the Uniden's HomePatrol Extreme features for the PSR-500/600 and 800 and be able to view on a computer screen.
I'll second that!
And I happen to like GRE's front end much better because I enjoy the better sensitivity and ability to pick up distant signals. I rarely have a problem with signal overload and when I do, I can usually switch in the attenuator ri change antennas to solve my problem.I do still prefer the Uniden's front end design, however. Seems to be significantly better front end filtering and/or dynamic range than GRE's very poor design. Frankly, I seriously wish I could "Frankenstien" the Uniden front end with the GRE's back end IF section and add the Uniden's discriminator audio approach and make a decent final model in terms of the RF signal handling.
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; DROID X2 Build/4.5.1A-DTN-150-30) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
I was the same way wanted nothing to do with the 800 because of no keypad. I decided to buy one and since then I have not turned on my psr-500 or my pro-106 and those were my favorites, I love the 800. I would want a keypad on the base unit though.
Exactly....once you learn to navigate with the four way button and the menu button you can do it without even looking, and quickly.
The school of though against this scanner reminds me of all the complaining I heard when scanners quit using "banks" of "channels"....some people don't adapt very well.
I too would like a Frankenstein, but I want some of Uniden's features with the GRE radio.
The one thing we apparently agree on is that the narrow filter for NFM is essential and that issue is not clear to most users. That's why some believe one scanner model does handle NFM (because there is a setting - lol) while others realize it doesn't.
Mike, I am an RF engineer as well and understand/agree what you mention about what can be designed. But price is an issue for these scanners, as they wouldn't sell as many if they charged what they feel is necessary to recoup the cost of a great design.I notice virtually no significant difference between the sensitivity of the GRE and the Uniden I have. There is a common bad misconception that better front end sensitivity means a compromise in front end rejection of out-of-band and near-in-band strong signals handling. Correctly designed, with proper consideration of BOTH band-pass filters AND dynamic range (which very few non-RF technically experienced folks seem to understand
My tagline is a fraction of what I have and use. I was able to have a longer tagline until I wanted to post links to my two streams. The text for a link uses up a lot of characters, so I had to list a select few scanners, and only one stream.gmclam, you say "I have a lot of different radios here, both brands" your GRE models listed are GREat ... but curious about what Uniden models do you have ?
Yes. And that also does not include others' scanners I have in my possession from time to time for programming, etc.I am thinking that your have more scanner that are just listed in your signature perhaps ?
No. Purchases vary from full list to sales to used.btw ~ You can see I am biased to GREat scanners, hmmm sounds like Shack discounts right
I am not sure who made it, as it was circa 1974. The PRO-10, which is the same model but with UHF, was one of the few triple conversion receivers out back then.ps ~ Who OEM'd the Pro-77 ? ( Was it a Uniden made for RS model ? what does the RS date code say ? xxAxx ? )
I am speaking from personal experience when I discuss things like sensitivity. I have a lot of different radios here, both brands, connected to the same antenna system, and the GREs have always outperformed the others. I don't have problems with (front end) overload like many claim with GREs.
I also agree that while it is far sexier to develop and sell "features" rather than "performance"; it is quite ironic that I encounter all the firmware and software bugs and issues I do. Some of this stuff looks like it was written by someone who has never seen/used a radio and done in "spare time" rather than with professional intent. I am working on a "review" I hope to post soon that clearly points out the shortcomings (in hopes that someone will pay attention and get them corrected).
The PRO-92 is a 5v design and not as sensitive on UHF as newer models. The PRO-93,'95,'97 are all essentially the same receiver. When it comes to sensitivity, I've had them connected the same antenna (with passive splitter) side by side next to different Unidens and able to pick up signals that Unidens didn't stop at. In all fairness, with scanners, sensitivity is also a function of scan speed, so it could be related to that and not the actual receiver.All I can vouch for is my one BCT15, two 197s, one 500, and one 310 (essentially four GREs and one Uniden).
I also have a strong VHF paging signal at ~152MHz but it only presents a problem through my multicoupler AND with certain model receivers.The BCT15 I have matches in sensitivity my GRE's for all practical purposes and suffers from far and away less front end overload (I have strong pager signals near me that play havoc with the GRE's on VHF-High band but do nothing at all to the Uniden BCT15).
I am more likely to hear the paging interference on the PRO-9x scanners than the PSR-300 or PSR-310. I have not experienced other "filtering issues" with the GREs....when listening to many close in VHF-High signals simultaneously - the GREs will have a nasty background of pager junk but will adequately separate the close in adjacent channels (poor front end design but good IF filtering) while the Uniden will have zero pager junk but can't separate the close in adjacent channels such that I can sometimes hear two or three adjacent channels simultaneously when parked in the center (poor IF filtering but good RF front end design).
I could agree with that, as long as done properly and no corners cut. Otherwise, they are better leaving it as is. The 20dB attenuator can get many people out of some jams.To my mind, GRE's primary focus, to gain the most bang-for-buck RF improvement, would be to improve their front end dynamic range. If they could do that, it would significantly improve the end-user experience with these units in RF dense areas for in-band strong signal handling.
The GREs do have band pass filters on their front ends now... and yeah I can think of one NOAA transmitter that, when I am within 1/2 mile of it, I will hear it on an image when the service on that frequency is transmitting. Since I am not near NOAA, nor anything of that power level (100KW), it's not an issue for me.Filtering (in the RF front end) can only help for out-of-band interferers anyway and cannot help with strong signal in-band undesired signals such as in-band pager transmitters, taxi transmitters, and NOAA transmitters - some of the most problematic signals for consumer scanner receiver equipment in the VHF-High range
Again, if I happen to be a dozen yards or so away from a cell tower I've experienced this problem. Kick in the attenuator and it puts a band-aid on the problem for the moment....improving the dynamic range of the front end amp for the 800MHz range will likewise improve the receiver's performance when in the presence of strong in-band signals such as in-band Nextel transmitters, other constant signal transmitters (undesired other system control channels, etc.) and near in-band signals like cellular transmitters (non-Nextel) - again, even with no additional filtering which is useless for in-band stuff anyway. 800MHz in-band overload is also a common problem for the current GRE models.
Mike, I pretty much agree with your assessment/comparison of the two brands. Some might wonder if the design differences are because of different RF designer talents or cost or "that's the way we've always done it" or what between the companies. While a good design with certain filters and variable gain RF amps looks great on paper (it is THE way to go), you know there has to be a real reason it hasn't been implemented. I would be concerned about how much extra cost the proper design costs (that's why there are receivers out there that cost a heckuva lot more) as much as they could make things worse.One can argue back and forth that this unit works good in their particular area and that one doesn't and someone else can say the reverse. The problem is that each area has different RF environments. Just assuming one "dense" area is the same as another is outright wrong.
I agree; without the keypad I feel I have "lost control" over the scanner. What would be nice is to have a 500 with the capabilities of the 800 and a better, that is "clearer" display.
