It depends to some extent on whether or not you are using a single ended or a balanced input. If single ended, you can make a suitable antenna using a Slinky. Yes, the toy. Buy one which is bare metal. Here is a link to the basic method,
I have used one before, and they do work pretty well for an indoor antenna. You can make a dipole version using 2 Slinkies. solder the center conductor of your cable to one, and the braid to the other, and strech them in opposite directions. I suggest using nylon string for the support line inside the slinky since nylon is a good insulator and is resistant to moisture.
