The quote feature is not working today so I am cutting and pasting wmbio's post:
You did not look very hard! #1 on the First google search I did. Pro-34 beep disable.
With the top cover removed as described above, locate connector CN3, a 15-pin connector with colored wires at the front of the main circuit board. There are two procedures which will stop the beep tone from being heard through the speaker; read both to decide which procedure you want to follow.
(1) Find the center grey wire coming from CN3 and cut it midway to disable the beep tone. You may wish to solder a resistor in series to reduce the beep volume, a trimpot to vary the volume of the beep tone, or a minature switch to choose between beep and no beep.
(or)
(2) Using a pair of needle-nose pliers, CAREFULLY pry the plug from CN3, revealing a row of pins. Locate the center pin (#8) which corresponds to the grey wire and bend it down flat, disabling the beep circuit.
Reinsert the plug. The pin may be erected again later to restore the beep tone if desired.
This completes the restoration procedure. Reattach the cover and replace the screws.
wmbio
***END OF QUOTE***
You did not read very well. That is the mod for the Pro-2006, taken from the Radio Shack Mods FAQ on Usenet. I am familiar with that mod because I have done it. There is no Pro-34 beep disable mod in that FAQ.
Source:
http://groups.google.com/group/alt....sable+"pro-34"&rnum=17&hl=en#741c136993d06dfa
