BCD325P2/BCD996P2: Any way to turn off 'Control Channel Only" mode?
Tim
Milwaukee, Wi
Greetings,
I may be blind, but is there way to turn off this feature?
Currently, I monitor a 15 channel Motorola SmartNet TRS in which one of the control channels stays keyed up (When it's NOT being used as a control channel). Strangely enough, it's as if only that frequency is in failsoft mode, but without the failsoft mode beeps.
Tim
iMONITOR
Silent Key
S.E. Michigan
Try pressing the Control Function knob to toggle between ID SCAN or ID SEARCH, then press Scan/Srch.
Tim
Milwaukee, Wi
I am not having trouble with talkgroups, it's one of the system's frequencies (852.0375) that is constantly transmitting like someone has an open mic. In 20+ years scanning this system I have never experienced this before.
The main problem which is occurring is that when a talkgroup (Let's say tg 16016) uses this frequency, the scanner will act like that 16016 has an open transmitter after the transmission has ended. Then while the radio is doing this, other talkgroups that happen upon this frequency will transmit via the tg 16016.
This particular frequency (852.0375) is one of the four control channel used by the system. I locked 852.0375 out of the quick key folder, but obviously 852.0375 comes up again in Control Channel mode when another frequency is being used as the control channel.
What is even more odd is that the Uni-Trunker program acts like nothing is unusual. It doesn't show any open transmitters and when a talkgroup uses 852.0375, it will show that talkgroup as using the frequency (Vs what talkgroup is displayed on a different scanner). I hope this all makes sense.
Tim
garys
I don't have a P2, but I had a XT and it was possible to turn off Control Channel Only mode. At least you could do it with ARCXT software. I'd guess that it's possible in the menu system. In ARCXT, it's under the site tab, so you may have to drill down in the menu system to find it.
UPMan
In Memoriam
Arlington, TX
Turning off control channel only (if that were possible...it isn't) wouldn't fix your issue.
Make sure end code detect is enabled for the system. That is the signal that tells radios (and the scanner) that the current comm is over. If detected, the scanner will immediately return to the control channel regardless of any continuing signal.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
May I suggest you take a look in the system's settings (the trunk system, not the global scanner settings) and see if End Code is set?
I would suggest setting it to Analog+Digital.
Ubbe
Stockholm, Sweden
If the radiosystem didn't sent an endcode the users should have the same problem. So check that endcode setting. The basestation could have been set to continous transmit mode by the radio techs for some purpose, maybe interfere hunting or plain forgot about it after a service check.
/Ubbe
GTR8000
NY/NJ Database Guy
BEE00
Is the scanner in a fixed location? Indoor or outdoor antennas? Do you have another scanner or receiver you can use to monitor 852.0375?
I'm wondering if you've ruled out local interference as the cause of the issue. The best way to do so would be to monitor 852.0375 in analog mode, checking for carrier activity. Using a different receiver both in the immediate vicinity of the scanner in question, as well as moving away from it and checking the surrounding area/property. You might also try a different antenna on the scanner in question, see if that changes anything.
It's certainly possible that one of the system repeaters is dead keyed. Is this a simulcast cell, or standalone site? It doesn't seem like they would purposely dead key it if there is live activity on that frequency, so it could be a hardware malfunction.
Ubbe
Stockholm, Sweden
Keying up the basestation manually and live traffic doesn't interfere with each other. When I did site checking I keyed up all channels and kept an ear on all TG traffic for interference signs while checking receiver sensitivity and desense and everything else on one basestation at the time.
I never forgot to unkey but collegues did and a basestation could be keyed up until next site visit.
/Ubbe
W8RMH
Feed Provider Since 2012
Tim
Milwaukee, Wi
To be honest, since that feature was available on the first trunktracking scanners i have never used or changed the settings. I 'enabled' it for this system and it seems to have done the job. Thank you very much UPMan.
I have heard the open frequency (852.0375) on several different scanners (Including while mobile) so its definitely the system and not my equipment. I have not heard any complaints of an open transmitter when the talkgroups come onto this frequency so i thinking the end users are not aware of it happening.
Tim
UPMan
In Memoriam
Arlington, TX
All of the system radios are going to pay attention to the end code. It is possible they have not noticed that they are having a system problem.
