Anytone Anyone 868 DMR programming issue
Jake71
I have a code plug that has worked great for over a year now. Then I recently open the plug in the CPS and changed a digital frequency. Now that channel longer transmits correctly. I tried changing other different frequencies and had the same result. However, any digital frequency that was not changed still works correctly. Does anyone know what is going on, or how to fix this problem?
mitaux8030
Silent Key
Home
This is a common problem.
The root cause is that the codeplug was built under version X software, but then loaded on to a radio that is running version Y firmware. CPS and firmware must always match.
So when you update the firmware, you must also update the codeplug with the same version CPS software. And you can't just load the old copdeplug into the CPS software and send that to the radio and consider it 'updated'... you have to 'rebuild' the codeplug by exporting everything, starting a new codeplug and import everything.
This is a major problem of sharing codeplugs. Someone receives a codeplug and has no idea what version firmware it is compatible with, and consequently runs into exactly this problem. Unfortunately this is just the nature of how things are with these sorts of complex software driven radios.
Jake71
Thank you for this information. I believe this exactly what happen. So, if I export a brand new code plug from the CPS to Excel, then import my current information from another Excel file, then import everything back into the CPS and then finally write the new code plug to the radio, in theory every should work? Am I correct on that?
mitaux8030
Silent Key
Home
You don't even have to import to excel. Just do the following steps:
1) Load your existing saved codeplug into CPS (latest version you have)
2) Go to Tool > Export, and save the file with a unique name
3) Figure out what MODE or band the radio is presently set to. Use menu Model > Model information. Under Frequencys you'll see a MODE number. Write it down.
4) Copy down all your Optional Setting - take screen shots or write it down by hand. This information isn't backed up by an export from step 2, unfortunately.
5) Start a new codeplug. Use menu Set > Set Initialization
6) Confirm the new codeplug is using the same MODE band from step 3. Use menu Model > Model information. Under Frequencys you'll see a MODE number. Make sure it is the same number you wrote down in step 3.
7) Now use menu Tool > Import and load the unique named file you saved in step 2.
8) Input all your Optional Setting from step 4.
9) Save file, preferably noting the version of CPS software you're using in the file name.
10) Reset the radio by holding PTT and the button directly underneath it while turning on. Confirm the reset. Once done, write the codeplug to the radio. That's it.
This process is called 'rebuilding' your codeplug, and ensures the entire codeplug data is freshly created & consistent with the version of CPS & Firmware in use. It needs to be done every time you update firmware version in the radio. Otherwise, it should be good to edit, add, etc any channels or other changes you want to make without this rebuild process.
Jake71
Thank you so much. I really appreciate your help and the information you provided!
