Anyone already using the so called Donut Antennas?
Dirk_SDR
Germany
At Amazon so called "Donut Antennas" are offered recently for SDR RX.
There seem to be 4 types:
1. AM: 0,5 - 1 MHz and 1 - 2 MHz
2. SW: 4 - 12 MHz and 12 - 24 MHz
3. VHF: 80 - 150 MHz
4. UHF: 400 - 470 MHz
What do you think? Useful or junk?
dlwtrunked
It looks like an unshielded loop in a flat configuration with a tuning capacitor. Depending on your SDR and money, you can likely find better (something shielded), but if size is a strong consideration these "donut" (really loop) might be considered. (If you have an AirSpy HF+ Discovery, the Airspy Youloop is great but other SDR will not have enough gain for it).
krokus
Southeastern Michigan
The VHF & UHF loops might be fun to play with, but the loops for AM BCB & HF/SW are questionable. If loops that small were effective, for those freq ranges, there would be more of them.
dlwtrunked
I think they may have been primarily intended for direction finding. For direction finding, small size is often desired and too much sensitivity can be a problem.
krokus
I had not thought about that aspect. It does seem odd they would try that with a SW specific antenna.
dlwtrunked
I have a commercial HF (SW) loop antenna that I have used for direction finding to locate a mysterious beacon. It was only a little larger.
johnmblack
They are not bad. The MW loop works pretty well and has sharp tuning. The SW one is so-so. Both are useful and at least outperform a telescopic antenna on my Malahit radio.
Dirk_SDR
Germany
wobble8
San Diego, Ca.
Like are found in thousands of 40's - 60's tabletop AM radios? Just sayin'........
ratboy
Toledo,Ohio
I have one of the blue SW ones, and it works pretty well. Just the fact that it doesn't flop around or fold up like the whip does on a couple of my radios is a huge plus. It was like $5, so why not?
satellite909
Tampa, Florida
I just received one today via Amazon. Not bad at all, the photos of them may appear to be cheaply made, but that’s not the case. Installed it on my Icom ICR6 receiver and seems to work very well. I will experiment more at night with better propagation. So far so good, and also noticed strong signal levels and clarity on the UHF FM 800mHz frequencies.
Voltaire
This is my experience with the antennas as well. They are not as good as my SV2CZF PL250C as they are not seemingly directional (which is odd for a loop) but they are much quiet and pick up signals much better than the telescopic.
My cons are: They are not seemingly "Directional" like a traditional loop(I do not know why at this time, possibly the design itself.) And the high/low switches and knob tuning seem to be "off," 4Mhz setting on the SW "donut" tuned up all of the 80m band without any issue. Very strange, but it does work.
I agree that a larger loop is better(MLA-30, etc,) but for the money and size these are definitely worth having in your kit.
Dirk_SDR
Germany
My cons are: ... And the high/low switches and knob tuning seem to be "off," 4Mhz setting on the SW "donut" tuned up all of the 80m band without any issue. Very strange, but it does work.
Possibly the receiver input adds some capacitance to the LC circuit (= the donut antenna).
