OK two disclaimers before I state my question:
1) Yes, my question is about GMRS, but the antenna in question is a 6m/2m/70cm amateur radio antenna, hence my choice of forum.
2) Yes, I *know* this isn't a GMRS antenna. That's not the question, but thank you anyways.
3) Yes, I know that SWRs can vary depending on the installation, or even between two antennas that are "the same".
If anyone has that antenna and a NanoVNA (or other SWR meter), could you please sweep the antenna in the GMRS range (462.x and 467.x) and give me a ballpark SWR reading? I don't need exact figures (although I will certainly take them), but I'm curious if they are < 2:1 (or close) or more like 4 or 5:1.
I am looking at swapping around a couple antennas, and my current plan is to take the Diamond X50NA that I'm using for 2m/70cm and replace it with a Comet CX-333 so I get 1.25m too. (I'm also hoping for better performance on 2m/70cm.) I would then take the X50 and use it for GMRS. (Again, I *know* it's not a GMRS antenna, but for the limited amount of transmitting I do on GMRS it's close enough.)
It occurred to me that I could instead install a Diamond V2000A and pick up 6m (the reviews suggest it works well on the FM portion, which is what I'm interested in anyways), but I'm wondering if it would work "well enough" on GMRS to use it for that too. If it won't, then I'll probably stick with my current plan for the X50 and continue to use a 6m ham stick stuck on top of my truck when I want to work 6 meters.
Thanks in advance!
Thanks in advance!
